Waht is the correct program code for swim pure plus t9 cell A0 or A1?
I believe those program codes set the name of the control. To set the cell type, set the main toggle switch to “auto”. Then press the diagnostic button 8 times or until you see the “T” number. Slide the toggle switch to “super chlorinate” and then back to “auto”. The cell type will change. Repeat this process until the cell type displays T9.
If T9 does not appear, you may have an older software revision. In order for the T9 to work, you must have a revision of 1.5 or higher. You can press the diagnostic button 7 times to see the revision number.
Well, it’s more like A0.
