Problem with minimax CH high performance millivolt heater
Noticed pool water was lower in my pool and after investigating I noticed a lot of water on the ground near my heater. I turned off the pump/main switch and heard water dripping from/out of the heater. Has anyone experienced this or know what my problem could be?
Hello Jrinney5 - The water could be leaking from a couple different places. The most common are the heat exchanger, header and bulkhead fittings. You’ll have to inspect these areas to determine where the leak is coming. Check out our schematic and parts list for the Pentair Minimac CH.
