Pool Wall
I am looking for a replacement wall 24 foot 52 inch.
I also need a new liner for the same size.
Hi pandeinvestments,
Could you post a few photos of your pool to this thread.
  • One which is a wide shot of the pool showing the wall pattern
  • A close up shot of the top cap
  • A close up shot of the top plate
  • A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
The pool is from 03 and is called a Kingston.  I do not have the wall but it just had a folded over edge and was beige.  I believe that the actual wall height was about 51".  If you have some thing that is 51 to 51.5 inches, I should be able to make it work.
We do not have just the wall for this exact pool, probably the least expensive option would be a complete 24’ Round Above Ground Pool Frame which is $989.
