Pool Wall Replacement
Hello, I need to have my pool wall replaced as an economic solution to replacing the entire pool and deck. The pool company suggested I go online to find the replacement wall but Swim’n Play, Inc is no longer in business. Do you know where I might be able to find it? It is a 15x30x52 above ground, oval shaped pool. The wall listed in the packing list says 30x15 gray solera wall. No luck online so far. Any help you can offer is appreciated.
For pool walls, we recommend trying https://www.thepoolfactory.com/pool-supplies/replacement-parts/above-ground-pool-parts?rp_part_type=465
Thank you, Rob! I will give them a try now. Be safe during this tumultuous time.
You’re welcome. Take care.
