New Home purchased. Our 2015 inground pool has Pentair white lights, one in spa which is super bright, same size unit in small pool very dim. Transformer is Intermatic PX 100. All installed same time.
Confusion why Spa light so bright. Neighbor had same issue. They changed the pool light and after 1 month same dimness on pool light. Pentair says probably a transformer issue. Any ideas? We would like to get colored lights worried same will happen.
Thank you for contacting Inyo. Are your current white lights LED? What is the diameter of the face ring on the pool light?
Reply from Hincede - tried to respond to your thread but unable to find the field to do so. You asked about our lights, yes white LED Pentair Lights, best memory 3-4” outside housing same size for spa and pool 12x22.
The problem is that they put a spa size light in your pool. You are limited to what you can use. None of the LED lights will be brighter in the pool.
The only spa size light that is brighter is the Pentair Aqualight. They have a 250 watt option but it is only available in 120V. Your current lights are 12v.
