Pool was damaged by tree and will require replacement parts and fix. Need top rails and vertical, plus.
Please see attached pictures. Do you have replacements parts and a fix to for side wall. Thank you.
Hello Anthony - This looks like a beige J4000/Concord model. What is the size of the pool? What is the height of the wall?
24’ 52" invoice states Taupe Harvest(ATL J42452) puchased 3/2009
Thanks.
Hello Anthony - Harvest is the name of the wall design. The taupe parts are no longer available but the beige parts will work. Below are the parts you may need.
Top Rail - Part Number TL10053
Upright - Part Number 1440434
Top Plate - Part Number 1320143
Slotted Tube - Part Number 1470100
Top Cap - Part Number 1490546
Top Cap Support - Part Number 1490520
All of the items listed above are in stock. However, we do not carry walls. You may want to try https://www.thepoolfactory.com/pool-supplies/replacement-parts/above-ground-pool-parts?rp_part_type=465
