I have a waterway HI-FLO 48 Frame Pump. Part # PH2200-6RP. Model SD-20-2N11CD
The motor has 2 speed (low & high). It works fine at low position but it just hums at high position.
Does this sound like a capacitor issue?
If it is, does anyone know the correct start & run capacitor that this motor has and the cost?
I want to order the part first before i open up the motor. At least it is running on low position setting.
If it help, here is the motor info:
Type F/C = Century, Mexico
Motor Mod: C48AA70A79R, SER: 31913J2 HP 2.0 - .25 SPL
Volt: 115, Amps: 13.5/4.7
PH = 1, Code = E
RPM = 3450/1725, FR = 48Y, HZ = 60
AMB = 40 celcius, Time rating = CONT
thanks in advance
