I have a Hayward pool pump. The model and part no. are missing. The patent no. is 299143.
The pump is pre 06. 2" inlet, 2" discharge. The motor is a AO Smith 2 speed.
Motor, B977, Frame X56J, RPM 3450/1725, 230 volt, Hp 1.5-2. The motor info should give me the shaft seal. I still need info on the pump housing. The case gasket fits into a round groove on the pump case. It is about 73/8" im diameter.
Will appreciate any info.
Thank you,
Robert
