The pump gave out on my hayward superpump 2610x15. The motor was an ST1102 from a.o. smith.
I have taken the pump apart, the motor is definitely end of life.
Question–can I reuse the old impeller, diffuser, etc and get a gasket/seal kit. There does not seem to be anything wrong with the old pump assembly. Just the motor, I am pretty sure the bearings have seized up.
The motor is at least 10 years old, and possibly 15 or 20.
The system was upgraded to salt 6 years ago, but the pump and motor were not replaced at that time. No reason to, they were okay.
Any suggestions? Like what gaskets and seals I will need, and if I can reuse the pump.
regards,
David Troutman
