Pool Pump Replacement
Needing to replace an existing pool pump filter for a Hayward 4820 DE filter system.  Pool volume approx 16,000-17,000 gallons.  Would like to check into a variable pump if recommended.
We’d recommend the Waterway Power Defender 165. That is a 1.65HP variable speed pump. It has 2" ports and a built-in timer. Click Here to View More Details on the Waterway Power Defender 165
