What replacement parts do I need. 0-164303-23. Frame M56J
It’s a Century Centurion pump. An electrician checked the load and said it’s fine. No noise
When a pool pump is run dry for a long period of time it can generate heat from the motor shaft seal spinning with no water flow to cool it, and you might have damage to the seal plate and impeller as well. We would recommend opening it up and inspecting it before purchasing any parts so you are certain you have everything you need.
This guide on [how to replace a pool pump shaft seal ](/Forum/thread/pool-pump-ran-without-water-for-months/How To Replace a Pool Motor Shaft Seal)will get you started. Let us know the model number of the pump that the motor attaches to (or send pictures of it) so we can direct you to the parts you might need.
