I believe the motor is seized, it just hums. After opening the pool everything seemed to be working well then the pump just stoped and the motor humed. It felt extremely hot. I’d like to just replace the motor so I don’t need to fool around with the existing fittings. The recommended motors don’t match with current specs (11.0 - 10.2). I also believe that i need to replace the impeller ring and shaft seal and want to order the correct parts…once
The correct replacement motor is this USN1202 Motor which is commonly used on this Hayward Northstar which will require this Hayward Northstar Shaft Seal.
