I am replacing a hayward super pump motor with a century. After replacing the motor has a clicking sound to it and not working at full strength. Any suggestions?
Hi Peterpin,
I would check out our Video on Why is More Pool Motor Clicking as we go over the most common reasons that cause this. Do you know if your circuit is 115V or 230V most motors come pre-set to 230V and if you are needing to wire 115V you will need to switch the motor from 230V to 115V.
