I need a replacement motor. One cycle runs fine but the others do not and the motor runs hot. Model Century C48L2PA105C4 and is attached to a Jandy Stealth Model# SHPF 1.0 HP 1.0. What replacement would you suggest?
The replacement for the Century C48L2PA105C4 is model SQ1102.
We’d recommend replacing the shaft seal when replacing the motor. The shaft seal for SHPF models with a serial number before P08FF0001 is part number 5020-086. The shaft seal for SHPF models with a serial number after P08FF0001 is part number 5020-087.
