Is a ST1072 the proper motor for a Leslie Hydramax II pool pump?
If so is there anything else I should purchase to install this motor?
Does instructions come with the motor>
Hi Charles,
Could you supply us with the following information off of your motor label?
Once we get this information then we can make the proper suggestion. Also if you wanted to post a few photos of your motor label as well as your complete pump that would be quite helpful.
