Pool Pump gasket replacement
Hey Inyo,
I have a leak in between my pool motor and the pump. I assume that this is a problem with the gasket between the two. I was hoping you could help me find the correct gokit to do this repair myself.
The labeling on the cover and the basket inside say SP-1600-D. I could attach pictures if you need more info.
Thanks,
Jon
You have a Hayward Super Pump. The seal kit is **GOKIT3**for traditional chlorine pools or GOKIT3SALT for salt water pools.
thanks rob! ill give it a try.
jon
You’re welcome, Jon. Thank you for shopping with INYOpools.com!
