HI can you tell me what bearing kit I need to replace the bearing on Hayward SP2615Z1ECM . This is a variable speed motor thats making a lot of noise. Also does it come with new shaft seal?
Unfortunately, we do not have a parts list for that particular motor. If you take the motor apart, there should be numbers on the bearings.
The bearings do not come with shaft seals. The shaft seal for that motor is part number 5110-11.
