I have a 12,900 gallon pool currently running a single speed 2hp Hayward pump. I would like to switch to variable speed, what do you recommend for this size pool?
Thank you
Thank you
2HP seems high for a pool that size. Are there any other water features that use this pump? Waterfalls, deck jets, spa, solar panels?
Yes, there is a spa and waterfall.
thank you
We’ll assume that it was properly sized to handle the spa and waterfall. In that case, you’d want a VS pump that is 2HP or higher. We’d recommend the Waterway Power Defender 270. It is a 2.7HP variable speed pump.
Click here to view the Waterway Power Defender 270
Great, thank you.
