pool pump
i am looking to replace a P2R-A5E-124L with a dual speed, what would you recomend?
Hello Chris - We have a drop-in replacement for your Sta-Rite P2RA5E-124L. This means it will require little or no plumbing. The new ports will line up directly with your current lines. The replacement would be Speck EasyFit MXG model IG281-2100M-0DG. This is a 1HP 2-speed pump.
ChrisG,
Another option for you would be the Speck EasyFit MXG Variable Speed Pump this pump would be even more energy efficient than the dual speed and is also a drop in replacement for the Sta-Rite P2RA5E-124L. We also put together a really good article on Choosing Between a Dual Speed Pump and Variable Speed Pool Pump which may help you make your decision. The author is a really smart guy =)
