I have a USQ1102 century pump attached to p2ra5e-124l. Pump motor is getting loud. I believe I found the right motor but can u confirm what motor I need, as well as the correct o-ring/gasket kit? Don’t want to order wrong thing.
thanks…mike
thanks…mike
Yes, the USQ1102 is the correct motor for the Sta-Rite model P2RA5E-124L.
The GOKIT54 is the correct seal kit for pumps manufactured since 1998. It can be used on older models if the copper cone is removed from the seal plate.
