Pool Pilot Digital + Sta-Rite PHK2RA6E, Pump Won't Turn On
Pool pilot seems to be working normally, but when I try to turn the pump on using the Pool Pilot interface, there’s no sounds at all, and the “check system” light starts flashing.
I took the cover off the pool pilot this morning and made sure none of the fuses were burned out and that none of the boards were damaged.  Everything looked clean and normal.  Last week, the circuit breaker tripped for an unknown reason.  I reset and everything ran fine until 6 days later when I noticed the pump wasn’t running.
Equipment is probably approaching 8-10 years old, as the pool was installed between 2008-2010.
16500 Gal/Autopilot Pool Pilot Digital 220/Sta-Rite PHK2RA6E/Pentair System 3 S7M120 Filter
