Pool parts
I received a pool that has some rust on the botom rails and I am needing to replace some of them.  I measured the curve, width and from side to side.
Curve - 55 1/2"
Side to SIde  - 55"
Width - 3/4
I found a part number on the top cap (P/N 361X28) its  a2 piece design.  I am unable to find the manifacturer of the pool.
Hi CBurgess99,
Could you post a couple of photos of your pool as this would help us determine the parts you need? If you could post a wide shot showing the pool wall pattern, a close up shot where the top rail meets the upright as well as a close up shot of the part # on the top cap and any other photos you think will be helpful.
To post a photo click on the Mountain icon in the text editor, see screenshot below or you can reply to the email you received and attach the photos.
Pool is disassembled right now. In total I need to replace 4 rails.
Hi CBurgess99, We have confirmed that your pool is not from any of the manufacturers we carry parts for. There are a few other popular above ground pool manufacturers that we do not carry parts for so it is possible you have one of there pools. I would suggest contacting the following companies to see if you have their pool and if so they can supply you parts.
Trevi - https://www.trevi.com/default.aspx
Ashai Pools - https://www.asahiparts.com/
Lomart Pools - https://www.lomart.com/
Cornelius Pools - https://www.corneliuspools.com/english/ht/index.html
Hopefully, you have a pool from one of these manufacturers and they can help.
This is a Swim’N Play above ground pool. For parts, we recommend trying https://mail.swimnplay.com/xcart/cart.php?target=category&category_id=2
