Pool motor replacement question
Is the “b2854, 717721624” the correct replacement motor for my A.O. Smith Centurion Switchless Motor (part no. 7-193986-24; serial 327093M; type cx; frame Y56Y; mount horizontal with vent holes down; 16718001;
Hello ScottFoy - Model B2854 would be the correct replacement motor for your A.O Smith model 7-193986-24. If you know the make and model of the pump side we can recommend the correct replacement seals.
I am replacing the same motor, my pump side is a Jandy PHPM1.5.  Can you tell me what seals I need to do this?
Edit:  Serial number is R09FL0903.  After a little more reading, I believe I need the new style seal (R0479400) - please confirm.
Hello Surly - Part number R0479400 would be the correct shaft seal. Thank you for shopping with Inyo!
Hi, what options do I have for a replacment motor for this pump and housing type? Thanks!
Century motor? Need motor and I assume kit for all the seals, etc.
