My suggestion would be to replace with an entire PL1615 PureLine Pure Flow Variable Speed Pump. The reason being is that the cost is going to be the same as just replacing the motor and you will get an entire new pump and motor. I like the PureLine pump as the pricing is quite a bit better than the Jacuzzi pump and I think it is as good or if not better, the PureLine also comes with a full 1 Year warranty.
