I own a 24ft round inground pool. I’ve only had it for 1 yr. It seems that I have a mole problem that is causing leaks. I have done the dye test and still can’t find a hole. My questions are : can A mole bite and cause holes in the liner?
or has the liner shifted because of the tunnels and this causes leaks?
should I drain the pool to figure this out?
help please!
Sorry that should say above ground pool.
Hi Jedwards,
Yes a mole could cause a leaking liner. I would follow this Article on How to Find a Leak in an AboveGround Pool which has help many pool owners find the source of there leak.
The best idea is to have help from the Leak Detection Contractor , they have all the equipment to find out the leaks in the pool and provide you the way to fix such leaks.Consult with such experts.
