We have complete LED fixtures that could replace your light fixture. Unfortunately, they are designed for spas and wouldn’t be as bright as your current 250w light.
Thank you for the reply. I am really interested in upgrading to an LED. Is there a bright LED option that will fit inside of the fixture housing that it already in the wall?
We carry the PureColors LED spa light model PL5861. This fixture would fit in your existing niche. However, it will only light up, at most, a 10’ area. We do not have anything brighter in that size.
What are the complete fixtures that you have to replace this? I have the same and am looking for a full light/niche replacement (as I believe the housing/niche has a slight leak that I’d like to fix when I replace the light).
Hi Paul, replacing the light niche is a very involved process. You would need to have access to the rear of the niche to glue the conduit in and this is only possible during initial installation or if you are doing an extensive remodeling of the pool.
If there is a small leak at the conduit fitting you can use a Cord Stopper to plug it up. If the leak is around the face of the niche, this AquaMend Underwater Repair Epoxy Putty should seal it up if you have a gunite pool.
Any replacement light fixture will be specific to the niche you have. Let us know what it is if you would like us to recommend a replacement.
Thanks Rich! I think I’ll probably start with replacing the fixture and trying the cord stopper. I have the same light housing as the orignal poster (#E41117, Label 98700600) that I’m looking to find a replacement fixture for my spa. Do you think the Pureline PureColors LED Bulb & Spa Light Fixture Kit is the way to go? I would prefer LED and color options so that seems to be the way to go.
Hi Paul, that would be a good replacement, but, unfortunately, our stock on spa (and pool) lighting is currently pretty low and that item is out of stock.
