pool jet adjust air value blowing water
I am not sure what the valves are called on the spapool jets above them
out of the water of which I have six of them which you can adjust to close.
Anyway, one jet is not really blowing water/bubbles and water is coming out of the
value, I had to shut it closed so water is not being removed from the spapool.
What exactly do I need to do. The pool people here are criminals and I have paid
them once to diagnose a problem and was charged for the visit then they came to fix and charged for
that visit and the part too and they realized that was not the problem. Then they realized it
was the heat exchanger on the heater and they wanted 3 grand though I saw it all over
the internet for 2 grand and purchased it from you. I am happy for that.
So what is it exactly for the problem water coming out of the top value.
Hello Redpath - We’d be glad to assist you. What is the make and model of the valve? Is the valve cracked or is it leaking from a seal in the valve?
If you are not sure of the make and model of the valve, you can post some pictures of the valve.
forum
This is the jet and this is the value above.
I can remove the values from any other jet and water would not be come up like a faucet.
So wondering what the issue is exactly. By the way I ordered a new Whisper pump basket and whoa is it so much better than the OEM in quality in thickeness.
Can you find any part numbers on those items? If not, we’ll need some additional information. Pictured below are all the specifications we need.
This part diagrammed really doesn’t matter does it? I can unscrew any of the other ones with the jets running and I do not have a Drinking Faucet of water coming straight up at me?
The problem I have is the other jets work fine and you hear air being sucked into the hole from up top, I can remove the caps completely no problem. But one jet water is coming up through this hole and if I remove the cap it is like a water fountain. If I remove the  jet completely there is no water coming up anymore. I have no idea what the issue is.
The part diagrammed does matter. I’ll try and explain why. The jet has two lines running to it. One line is the water and the other is air. The dial on the deck is what controls the air flow to your jet. When the jet begins to go bad, it causes the water to back up into the air control valve.
Regarding the jet/nozzle, please provide the information from the diagram posted above.
It is Number 11 pushed closed shown below, it does extend when you pull it.
I guess I could swp out one jet with another and it should work but who knows maybe.
Then it would be the jet.
We can’t tell from the pictures what the measurements are. Can you just send us the measurements? You can title them face diameter, base diameter, total length. diffuser length and nozzle diameter. These are all shown in the diagram I posted.
The diagram marked
did you see my post of the diagrams?
Most of the jet styles like your jet have been discontinued. The closest we have is part number 210-6730. This is only available in white. If it doesn’t work, you can return it.
Sure I will try one
Great! Let us know how everything works out.
