My pool heater needs replacement. It was installed with the new pool in 2006. We rarely used the heater, and apparently rodents may have damaged the wiring. As I contemplate replacement, I have several thoughts:
1 Would it be cheaper to buy the heating unit online and find someone to install the unit?
#2 Should I consider replacing the natural gas unit with a heat pump that will not require the natural gas.
