Pool Filter
I have a Pac-Fab Nautilis FNS 36 filter that is about 20 Years old and it has a Push-Pull valve to backwash. The problem I have is it leaking at the top (is cracked), do you have a replacement that will fit my filter.
Hi JPT126989,
Thanks for your question. We are showing that the Pac-Fab Nautilis FNS 36 filter uses this 263034 Push Pull Valve.
I have a Hayward system pump as I replaced the original last year.  The filter is the original and it’s 8-10 years old.  It’s leaking through the backwash valve.  The sticker on the side of the valve is worn off and otherwise unreadable.  There is no model number molded into the plastic.  There is a number only on the top of the valve that reads 27-259 6/98.  Not sure what that is.
I can’t attach photos here as they’re too large of a file size.  Can I email them to you?
Thank you.
I am planning a replacement for my FNS 60 DE Filter and recently purchased a new filter grid for the current FNS 60.
1.       Will filter grid assembly (Item # 195070) fit with a new FNS Plus top (# 170022) & bottom (170018)? 2.       Is the plumbing for the FNS Plus 60 bottom the same as the FNS 60? 3.       Will multivalve (# 27507-200-000) fit the FNS Plus bottom (170018)? 4.       Will the clamp assembly on my current FNS 60 fit the FNS 60 Plus? 5.      What is shipping time for the top/bottom units?
Hi craigT,
I have answered your questions below in bold
Will filter grid assembly (Item # 195070) fit with a new FNS Plus top (# 170022) & bottom (170018)? No thefilter grid assembly (Item # 195070) will not fit with a new FNS Plus top (# 170022) & bottom (170018) however the individual grids within the 195070 will fit the FNS Plus.
Is the plumbing for the FNS Plus 60 bottom the same as the FNS 60? No they are different
Will multivalve (# 27507-200-000) fit the FNS Plus bottom (170018)? Yes it will
Will the clamp assembly on my current FNS 60 fit the FNS 60 Plus? No it will not
What is shipping time for the top/bottom units? For theFNS Plus top (# 170022) & bottom (170018) they are as follows. 4-7 business days.
