Pool Equipment
Hi
I am looking for proposals for my swimming pool
Pool size is 16m long x 5.5m wide and average 1.6m deep i wish to purchase a silent pump that can handle 8m head
i wish to purchase a salt water chlorinator and a PH adjusting device i wish for the pump and chlorinator to be fully programable to turn on at a pre determined time and duration each day
The Pool is located in Cebu The Philippines 230V-60HZ and is in a Tropical Climate and is used all year round
Could you get back to me with proposals for the best solution for my needs
Regards
Mr Hoffman
Hello Mr Hoffman - A quiet and energy efficient option for the pump would be a variable speed model. We recommend something like the Pentair Intelliflo model 011018.
We recommend the Pentair Intellichlor IC60 (Treats 60k gallons) for the salt system and the Pentair IntelliPH model 521377 for the acid control.
Since the salt system should only run while the pump is running, we recommend a simple mechanical timer. Intermatic model T104R3 would be sufficient.
Thanks for your reply
Normally for a pool this size hour many hours a day would you normally run the pump
Could you please forward me a quotation for all the parts including your BEST price and shipping door to door to the following address
Mr Anthony Hoffman
143 Sui Hang Hau Clearwater Bay Sai Kung Hong Kong …there are no states or zip codes for Hong Kong
Hello Tony99 - We have emailed you a quote which can be converted into an order online. Thank you for shopping with INYOpools.com!
I have a T104R.  I can see the wheels moving inside but the dial doesn’t turn.  I rewired the clock to terminals 1 and 3 and the clock is for 125 v.  What can I do?
Hi Jerry,
It sounds as your internal mechanism may be bad, I would suggest this T104 Replacement Timer Mechanism
