We recently purchased a pool cover. Because of some permanent decorative landscaping I’m unable to use a pool reel to remove the cover. As you can imagine, doing it by hand and putting it back on is a real hassle.
What I did to reduce the hassle was to build pool cover “panels”. As a result, only about 80-90% of the surface is now covered. Will this make a meaningful difference in evaporation and heat loss?
Thanks for your thoughts.
Gene
