We just put our 27 ft round pool up.
One of the bottom boot that attaches to the upright post and bottom fitting g is broke.
would this cause my pool to bow at that upright
thanks
thanks
I would suggest fixing the part. As there is a good chance of a problem in the future.
Hi, We’d be glad to assist you. For matching above-ground pool parts we will need any or all of the following information. Do you know the make and model of your pool? Pool Size? We will also need a few photos, please supply a close-up photo of your top cap, top rail, and a wide shot showing the pattern of your pool wall. Also if you can pull any part #'s from the top cap, normally this is stamped into the underside of the top cap so you may need to remove the top cap. If you have any documentation from the pool like the owner’s manual then if you could send us the page showing the parts diagram then that is always helpful as well. To add images click the mountain icon, see example below…
