Pool automation
I’m ready to convert to saltwater, but I want a controller that I can use remotely to check the salt level, chlorine level, Ph, etc as well as possibly control the heater, pool lights and waterfall.  What systems fit that bill?
Hi yzpmpqq,
Could you answer the following items below, this will help us size the proper system for you.
  • Is this a pool only or pool/spa combo?
  • Please give us a list of the exact equipment you would like to control
Pool only.
Heater - Hayward H250FDN
  Pump - Hayward Super II
  Waterfall Pump - A.O. Smith K56P2N103A3
  Pool Light - Not sure of the brand, but it’s a color change light (color selectable by flipping the switch on, off and back on.
For your set up I would suggest the following…
The above system would be an automation system that would control your pool lights, heater, pool pump and waterfall pump. This system would also come with a Salt System, Acid Tank and a controller that monitors your pH and dispenses acid accordingly. This system would allow for control from the outdoor panel or from the Wireless handheld controller. Please let me know if you have any questions.
Thanks Patrick
