My Polaris 360 will not cycle through the backup sequence. It gets stuck going backwards. I replaced
the backup mechanism and it went through one cycle and was stuck going backward again. I disassembled the backup valve and it appears clean and functioning. Any suggestions?
Hello Mgarlington - Have you checked to see if the cleaner is getting the correct pressure? You can do this by checking the revolutions per minute (RPM) of the wheels.
For maximum efficiency, the Polaris should operate between 28 and 32 RPM. 1. Mark the
Mark the single-wheel side tire.
Turn pump on, hold cleaner below water level and count wheel revolutions for 1 minute.
Optimum speed should be between 28 and 32 RPM.
If the count is less than 28 RPM:
• Check the filter screen in the Quick Disconnect for debris.
• Clean the skimmer, filter and pump basket.
• Check the hoses, connections and swivels for leaks.
• If the cleaner is connected to a dedicated return line, adjust the 3-way diverter to increase water flow. If
If count is more than 32 RPM, unscrew the Pressure Relief Valve until the proper RPM is reached. If an adjustable valve has been installed, adjust the valve to reduce the amount of water flow.
