The replacement motor is model UST1202. We also recommend replacing the seals when you replace the motor. I believe the label says you have a Super II Pump. If your lid is round, it’s a Super II. The seal kit would be GOKIT2.
Sorry I forgot to ask. Is any of the Dual Speed or Variable Speed fit this?
The ECM27CU would be the variable speed option.
The two speed option is B2979. This type of motor would require a switch to change the speeds. The switch is part number 2512556-001.
