I came across a pentair super flow pump with a 1.5 hp motor for a price a could not pass up since me 3/4 hp pump quit working. The gpm is way to much for my filter. Can i use a3/4hp impeller and diffuser on the motor to bring down the gpm
Hello Jerrycarter - You can use a 3/4 HP impeller and diffuser to reduce the gpm of your 1.5HP Superflo pump. You can view all of the available parts on our Pentair Superflo Parts Page.
Thank you for shopping with Inyo!
Thank you for your help my original pump was a Jacuzzi 3/4 horsepower since I am putting a 3/4 horsepower impeller on this new pump will it pump the same has my old pump as far as gallons per minute the old pump was rain on 220 voltage should I run this pump on 220 voltage also
It should be similar gpm with a 3/4hp impeller. You would still run the new motor on 220v.
