Got a Superflo pump motor that a bearing has gone out on. Can find bearing replacements for the Whisperflo, but not a Superflo. Anybody know if they are the same bearing, or are the ones on the Superflo different? Model # 356630S
The Whisperflo motors and Superflo motors are the same. In most cases, your motor would require two 6203 bearings. However, the manufacturer of the motors, Century, has changed the bearings periodically. Some versions of that motor use one 6203 bearing and one 6304. You may be better off buying two 6203 bearings and one 6304 bearing. That way you’ll have the correct replacements either way.
