I need to replace the pool pump motor. Can you guide me to the proper replacement motor?
Hello MacMac - We have two options that can replace your 7-177475-20 motor. The 1HP full rated option is model B2848. The 1.5HP uprated option is model B2854.
We would also recommend replacing the seals when replacing the motor. Do you know the make and model of the pump. If not, you can post a picture of the complete pump.
Thanks. I ordered the B2848 and the seal kit. On opening the seal kit, the ceramic on the pump seal was broken forcing me to buy a replacement locally.
However, all is installed and running like a champ now.
MacMac - We’re sorry to hear about the shaft seal but we’re glad the pump is back up and running. Thank you again for shopping with INYOpools.com!
