Hi
I have an in ground pool that has a Pentair pool light with an orange sticker that says
lamp p/n993650, lens gasket p/n 791016,
on the sticker it also says series 7884XX, 7844XX, 7894XX
watts 400, volts 120, bulb type R-40.
use with model no. 7821XX, 7822XX, 7823XX, 79206700, 79208900 fixture housing
I need to replace the gasket and bulb due to leak through the old gasket and the bulb burning out.
I was hoping to replace the white bulb with an an LED with color lights.
Is there anything compatible for the gasket and multi color LED light.
Im looking at
Pentair 79101600Z Lens Gasket Replacement Kit AmerLite Pool and Spa Light by Pentair
and
252 LED 120 Volt Color Changing Replacement Swimming Pool Light Bulb by Sunluway
Thank you for your time and help.
Sincerely, Adrian
