What are the replacement bearings for a pentair LA01N motor. I also need the replacment Capcitor too! Thanks.
Hi Robcg1,
For your LA01N you would need two 6203 Bearings and a 628318-307 Capacitor I hope that helps.
I have a pool pump motor Century Centuron 177451-03 that is running slow. Capacitor I removed from top of motor is Magnetek 175863-50. Do you have a replacement and what is the model #? Thank you!
My pump began making a loud noise. I suspect the bearings. I replaced the pump and all is well. I decided to replace the bearings in the old pump which is 6 years old. I purchased 6203-2RS/C3 bearings. On removing the old bearings the code was 6203 HL. What is the difference in the bearings and can I use the new bearings. Also the old bearings both seem to be ok.So what else could the noise be?.It is not to do with the impeller or diffuser since these are on the new pump. There was nothing in the pump which would cause the noise. Finally there are no split rings holding the bearings in place …is this normal. The pump is a century two speed 2 hp cat number B2984
I have an older in ground octagon shaped pool and need some coping connections
I had to replace my pump and the new one, Blue Wave Xtreme Flow, Mod# NE4516, has different size connections (2.75" o.d.) than original pump (3" o.d.). Now my existing pump to filter hose will not fit. Pump is Hayward, Mod#S180T. Any idea where to find unions or hose to fit? Thank you
Regards,
Paul
