PART#LUBE-10ML VS GO-KIT Seal Kits
Why do the pump seal kits (GO-KIT79) come with a PTFE Lubricant while the description for the PART#LUBE-10ML StatesPTFE Lubricant will destroy the seals?
Hi Cat52194,
The lubricant that comes in the gokit is designed for the o-rings and gaskets and not the shaft seal. It is not mandatory to lubricate your shaft seal but the LUBE-10MIL will give you an extra layer of protection on your shaft seal.
Would you reccommend using the LUBE-10MIL on the other O-rings?
Yes you can use the Sealube for o-rings. We recently had this customer review on this…
(5 out of 5 stars)  SEALUBE MAKES O-RINGS NEW AGAIN
Reviewed By:  Matt M. from Charlotte, NC (5/2/2016)
thought O-rings were shot but this stuff really works. thanks!
