I have a 20+ year old pool with a light housing that needs replacing… the pool niche itself seems okay. The label shows it as a PAC FAB, INC and has the following listed - Wet-Niche Type No. L-314376, Model 60-x30X, 300W MAX 12V R40 Bulb, Use fixture housing 62-xxxx. I’m guessing what I need is the fixture housing and the bulb but I’m not sure. To be clear I need the bulb and the housing that the bulb screws into. After a little research it looks like Pentair bought PAC FAB but that’s about all I’ve learned. You help is much appreciated.
You have this Pac-Fab Hatterass Light which is no longer available but can be replaced by this Pentair Amerilite we do currently have the Amerilite in stock but our inventory has been selling fast so I would suggest ordering sooner than later =)
