I have a Pentair Intelliflo pump model # 011018. Heard a loud noise this morning like bering issue going out. Is there a bearing in the pump itself or only the motor? Any recomendations? Pump runs but noisy as hell. Should I replace entire unit or attemt to repair. I am capable of repair if I have the right parts.Pump is 7 years old and runs 24/7. 3400 rpm daytime, 1800 at night. salt pool.
Hi, MarkShane. They are bearing inside of the motor. Due to the age of the pump, I would recommend replacing the motor - 350105S and the seal - GOKIT32SALT. If you would like to repair the motor, you will have to take it apart to get the bearing number off of it.
