Good afternoon … okay… I purchased a pump motor from you. Replaced the old one …pump worked perfectly…pump motor still works perfectly except it’s not drawing enough water to fill the pump reservoir. I replaced the shaft seal (again) I replaced the impeller and impeller o-ring/gasket; replaced the face place o-ring/gasket; replaced the pump reservoir lid o-ring/gasket; took apart the backwash valve and replaced the o-rings and gaskets on that; my pressure went from 10 to 0 and will not even move the needle. I also replaced the pressure gauge and o-ring/gasket. I need to get the pressure up so I can vacuum the pool! I’m not losing any water other than normal evaporation; there are no air leaks on the suction side at any of the joints… skimmer basket and pump basket are clean … you’re my last hope before I call in an excavation team and fill the pool in with concrete!!! Thanks!
Hello Jack - We’d be glad to assist you. We have an article titled “Why Are My Pool Jets Not Working”. It covers several reasons why you wouldn’t be getting any suction. Read through that article and let us know if you have any questions.
