Hello, I am in the early stages of planning an in ground salt water pool. I have a few questions on components. From what i can gather the order of operation is Pump, Filter (sand), Salt/Chlorine Generator----pool. Is this correct? Is there any other parts to the chain that i might need? Thank You in advance.
Hello Simon - You had the order of operation correct. Below is a diagram of a simple pool plumbing diagram. The salt cell would go where the check valve is on the return side (after heater).
Basic Pool or Spa Combination Plumbing
