Nevillsp
I am replacing a Jandy Stealth 2.0 HP motor  with a variable speed motor. What models would you recommend?
Hello Neville - Do you have the Jandy SHP or JHP Stealth Series Pump?
SHP
The replacement variable speed motor would be model ECM27SQU.
If you know the serial number of your pump, we can recommend the correct shaft seal.
