There’s a leak on the underside, near the gasket between pump and housing. Based on your responses to similar questions, I’ve attached two photos showing the pool pump and it’s configuration. Which kit do I need?
I searched around for similar looking pumps, and ordered the GOKIT3SALT (even though I have a fresh water pool), as the parts are supposed to be sturdier. Anyway, the replacement was pretty smooth, and this INYO pools process was a good step-by-step: https://www.inyopools.com/HowToPage/how_to_replace_a_motor_shaft_seal.aspx
Sorry for the delayed response. You do have a Hayward Super Pump and the GOKIT3SALT is the correct tune-up kit.
