Hey, I have a Jandy pool pump and the motor has overheated. I need to replace it and am hoping you can help. The pump is a jandy Plus HP. The pump model number is PHPF1.0 The motor part # 0-193986-24 serial # 20911CH. I will include pictures of the motor tag and other tags on the pump. Thank you!
The replacement motor for your Jandy PHPF1.0 is part number B2848. Click Here to View More Details on the B2848 Motor
We recommend replacing the shaft seal when you replace the motor. The shaft seal is part number 5020-087.
