Hello
. I need some help idientifying what motor is compatible with this Pentair pool pump. The tag has worn off but hoping you can identify from the picture. I️ actually have two pumps but not sure if they are both the same.Hi Dfrank522,
Thanks for the photos of your pool motor those were quite helpful! You will need this 2HP 56Y Replacement Pool Motor along with this Pentair Challenger Tune Up Kit
We also have a Video on How to Replace A Pool Pump Motor which you should find helpful when you tackle this project.
Thank you! Will this one also work, and is it a better motor? Or which do you recommend to last longer
Hi Dfrank522,
The B855 which you listed here https://www.inyopools.com/Products/03000017039422.htm would work perfect and would probably last longer.
