i would like to find a replacement for my light fixture. The pool is an old Anthony sylvan. The sticker is wore off the fixture. But around the edge of the lens clamp which is held on by 8 screws says model #20 wet niche type fresh water use only. And use with model 21 or 19la fixture housing 120 v 500 watt max r40. It has one screw at the top that holds it in the niche. I would like the replacement to be led. I don’t know if that means I need a special led fixture or a standard fixture and a led bulb. My fixture is broken so it has to be replaced. Please point me in the right direction
Hi Maisch,
You can go with the Pentair Intellibrite LED Pool Light. The trick is to replace the larger Pentair Intellibrite face ring with your old Anthony face ring to make it fit.
